You can check the speaker wire pair for "cuts or shorts" by unplugging the wire at both ends.
Put an OHM meter on one end, one probe to each wire, it should read "open" or infinite OHMs, if it reads 0 OHMs then wires are shorted together some place, you will have to run a new pair to that speaker.
If OHMs show open or infinite, as it should, then connect the two speaker wires together at the opposite end you are checking, OHMs should now read 0 ohms, wires are shorted together.
If it still reads open or infinite OHMs then 1 wire(or both) of that pair is broken(cut), no connection.
Replace wire.
If everything checks out, wire-wise, then that channel of the amp may be bad, you can test it on a "working" speaker, but it is probably bad.
You can run two speaker from 1 channel, in series, but you will lose the stereo effect.
Running a new pair of wires to a door speaker is not that hard, remove the kick plate and door panel, roll window up
You do
not need a large gauge wire, we are talking under 5ft and under 100watts here(closer to 10 "real" watts)
A 22 gauge will give the exact same audio quality as a 2 gauge, so don't waste your money.
You can usually use a short piece of stiffer wire to feed through the door's wiring channel then tape the speaker wire to that to pull it through.
Sometimes the old speaker wire is not connected(tape/tied) to the other wires going through the door channel, and you can use the old wire to pull through the new wire.
