no spark at the spark plugs or distributor
accarmonaa
i tested for spark at the spark plug and at the destributor cap and nothing i then checked for power at the connection for the ignition coil and have no power at that connector. where does the connection get its power from or how do i fix this issue???
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Standard or automatic transmission?
Does the engine starter crank the engine or does it just go click...or is it completely dead?
These are factors that you (we) need to better determine what it is...and what you've done so far will help eliminate things that you've tried...sometimes.
The distributor gets power from coil...coil is on the ignition wiring...ignition wiring is controlled initially by the safety neutral switch on the clutch of manuals...if that is not complete you get no power...on automatics the transmission must be in park or neutral (I think)...
So...even with the key on if there is something wrong with that
kimcrwbr1
46
maplevalley WA
2.8l
With the key in the run position you should have 12v at the ignition coil. If not you need to trace the problem through the ignition switch to the battery.
kimcrwbr1
46
maplevalley WA
2.8l
The computer is also powerd up by the ignition switch find the EEC relay it should click when you turn the key on run.
black_demon69
142
AZ
4.0l
memory fuzzy is this duraspark system?
kimcrwbr1
46
maplevalley WA
2.8l
My book shows the 2.3 and 2.9 with the computer the 2.0 had the duraspark. Either way the ignition coil is powered from the ignition switch.
6
New Orleans
'98
'94
'98
For
2.5, 2.3 & 3.0
Trying to be a better Christian than non-christians.
I'm surprised no one has said, "Check the fuse" yet.
kimcrwbr1
46
maplevalley WA
2.8l
If the starter works the fusable link is good!
jeremysdad
ASE Certified Tech
Not always 'good'. That just means it's passing current. You can bypass a fusible link and still get starter power. Like straight unresistored power to a fried coil, but that bitch will whip over like nobody's business.
I dislike misinformation. No worries.
I digress...
jeremysdad
ASE Certified Tech
It's TFI. Ignition module on the distributor? If yes, replace that part, then... Upgrade it. Duraspark II... more like Ford fail! Replace it with a GM Hei module. Pretty easy.
