bobbie58
- Jul 27, 2017
- 9
- bentleyville pa
- ford
- Engine Size
- 3.0
- 2WD / 4WD
- 4WD
I have a 2000 ranger with a 3.0 and a couple of weeks ago stopped at a friends house turned it off and had to get it jumped got it home , when you turn the key you would just get a click ,took the battery and starter to advance tested good, changed the positive cable ,installed new terminals and checked the wire ends, the pats key was broke off in the ignition cylinder but putting the black part in it worked , now not even a click , the lights all work I have a ecm but to try it does it need to be programmed to my vin# ? I have other ignition switches can I pull the transponder thing out of the broken keys and put them in the other keys or do I need a locksmith? I checked all the fuse and relays, im stumped
