No turn signals, 4-way flashers work - also no backup lights
mrbeezroom
San Jose, CA
Mazda B3000
I have a 1994 Mazda B3000 ext cab and none of my turn signals work. They were working a while back, albeit very slowly and weak. They recently stopped working altogether. My 4-way emergency flashers are fine (even when I remove the flasher unit from the fuse box). I checked the fuse panel and the fuses seemed fine. Installed a new flasher unit and it had no effect. I believe there is only one flasher unit located on the fuse box. Headlights, brake lights, and windshield wipers/washers are all working. The right half of my instrument panel doesn't light up (been like that for a while), most likely a bulb.
The truck is completely stock except for a shell on the bed.
The 5-speed manual transmission has been replaced/rebuilt.
My backup lights don't work (most likely related to the transmission work).
telsar
4
Houston TX
That heppened to me, also. It was the flasher/interuptor round thing in the fuse panel under the dash on the drivers side. I replaced it and they started working again. The emergency flashers worked fine the whole time. I got a new turn signal switch first, but it did not fix it. Mine is a 93 xlt 3.0 standard.
mrbeezroom
San Jose, CA
Mazda B3000
Replaced the flasher, but still no turn signals.
8,372
1994 and earlier used separate flashers for turn and 4-way
1995 and up used one flasher for both
Should be flasher on the front of fuse panel and one on the back side as well
Remove the front flasher and try 4-ways, if they don't work then front flasher is for 4-ways, back is for turn signals, but front flasher is usually for turn signals
In 1994 fuse #5 15amp is for the turn signals, AND Backup Lights, so its probably blown if turn and reverse lights both don't work
A fuse can "look good" and not be, so test or change the 15 amp fuse
Not an uncommon occurrence is that the backup light wires on the transmission can get melted by exhaust heat and short, so locate the wires, drivers side of transmission, and follow the wire forward and up to firewall connector
On a manual trans its just the 2 wires
On an automatic back up wires are hooked to NSS switch just above shift linkage, round plunger style switch with 4 or 5 wire connected
The wire from fuse #5 to backup light switch is Purple/orange stripe wire
mrbeezroom
San Jose, CA
Mazda B3000
According to my Owner's Manual there is only one flasher for both and I did replace it. The 4-ways work without any flasher at all. I'll look under the dash again for anything that resembles another flasher unit. Also, I've got a lot of fuses , so I'll replace some old ones with new and see if it helps. Thanks for your input. It gives me somewhere to start.
8,372
So you know there must be TWO flashers then :)
But the one you pulled out is the one for the turn signals or 4-ways wouldn't still work
With 4-ways on you should be able to hear the clicks and then reach under dash to "feel" the 4-way flasher working and where it is
Fuse #5
If you have a volt meter or test light check that one terminal in that fuse plugin has 12volts with key on
Fuses 5, 9, and 17 all get 12volts from ignition switch on the same wire, #9(30amp) is for Blower/heater fan, so if it works then ignition switch wire to fuse panel is OK
mrbeezroom
San Jose, CA
Mazda B3000
RonD,
Thanks for the help. I put another flasher in and changed fuse #5, and voila, I have turn signals. Next stop: backup lights.
8,372
Backup lights are same #5 fuse so check backup bulbs, you often don't notice when 1 goes out, only when BOTH bulbs are burned out
mrbeezroom
San Jose, CA
Mazda B3000
I'll check the bulbs, but I'm pretty sure they got overlooked when I had the tranny overhauled. Thanks again.:):icon_cheers:
