- Jun 2, 2012
- 8,370
- canada
- Ford
I have a hot water heating system, hydronic heating.
Using radiators, a boiler and one pump for circulation.
There are 4 Zones, 3 zones are working fine.
1 zone, the second largest, has limited flow.
It has 5 radiators and 1/2" copper lines between them but.......the lines are all in/below concrete slab.
The first 2 radiators in the direction of the flow will heat up hot but slowly, 3rd even slower and never hot, last 2 just barely warm.
So I concluded something is partially blocking the flow so the hot water is cooling off faster than it can flow thru.
The return line is almost cold.
I can duplicate the symptom on the 6 radiator zone by partially closing the out or return valve on that zone
System has between 15-20psi of pressure, I can close the 6 valves on the other 3 zones and pressure holds so there is no leak in this zone.
Valves "feel" OK, but I guess you never know.
Or could it be in a radiator, don't see how since they are literally just a copper pipe with fins, no bends, just a 90 at each end going down into the slab.
On each rad there is an air bleeder, pressure is of course, the same on all since this is a flow problem, and the hole for the bleeder is not really large enough to test flow.
Brain is drawing a blank on how to test where the blockage might be?
