Non flex-fuel 3.0 into flex-fuel Ranger
pianoman99
3.0L F/F
I have a 99 Flex-Fuel Ranger with a seized engine (from a CMP gear failure). I bought a 2007 non-Flux-Fuel Taurus 3.0L Vulcan. As I have already learned from the forums, I will be changing the head gaskets to a RWD type and I will be using all of my accessories including intake manifolds and injectors.
My question: I understand that the non-Flex-Fuel heads are different from the Flex-Fuel ones. I would really like to use the Taurus heads because the engine has only 14K miles on it. Should I bite the bullet and get my original heads rebuilt or can I use the Taurus heads? I never have or plan to use E85.
kawasakiman27
New Jersey
3.0 F/F
Just keep the non flex heads and don't use e85 ever again. My 99 flex has 2001 non flex heads and works fine.
JP02XLT
8
Indiana
The 07 heads will work fine, I did that on my 02, Mine are even ported & polished heavily. They will be fine. As for running e-85, it should not hurt anything either as you have the ECU to control spark & fuel.
JP02XLT
pianoman99
3.0L F/F
Thanks! I will be using the new Taurus heads.
evanesce69
11
Bridge City, Texas
The flex fuel heads would be worth the rebuild. They have a smaller chamber which increases the compression a bit, which is necessary for the use of E85. If you ever plan on using E85 in the future, spend the $$$ on the FFV heads.
If you decide not to rebuild the heads, maybe you and I can make a deal.....
:icon_cheers:
Rob
