Kahuna
- Jun 7, 2014
- 0
- Mazda
I just had my M5 tranny on my '94 Mazda B3000 lock up - trusting oil and lube shops is a F'ing crap shoot. Fluid was low/was a leak/no one told me ... so kabaam
Anyway, I bought and had put in a "guaranteed" used '97 Ranger M5 - and as is my luck, I found the tranny shop doing the work is a bit "lacking" in competence by not discovering this obvious issue in a test drive. I wouldn't trust them to diagnose a hang-nail. They didn't put in a complete shifter bushing set so the shifter felt loose and sloppy.
I put in a new shifter bushing kit thinking it would clear things up. It did as expected and did naturally tighten things up, but an odd issue remained with just 3rd-4th:
Both gears are loose like a worn shifter bushing issue - neither gears are holding tight - when in gear the shifter is still sloppy loose. Sometimes goes in gear(s), sometimes like the gear isn't there (like is in neutral); Sometimes can't get it out of gear without tugging hard - Sometimes like it's stuck in gear. I'm not an internal tranny expert, but know something of it - feels like something is "sticking" in shifter area, maybe from sitting and drying out? - maybe time and fluid flow will loosen things up?
