For Sale OEM Feedback Carb and Distributor
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
So, I have these. Been sitting in my garage since I did the Duraspark conversion. Worked fine before I swapped them. I also have a set of valve covers that say Bronco powered by Ford (V8) Pics on request or when I get a chance lol. Need them gone or they get recycled. 50 bucks or best offer, buyer pays shipping.
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
Any chance you have any of the valve cover 'keepers' that go under each valve cover bolt? I'm missing a corner one. TIA.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
No. Just the things I mentioned.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
So, here's my bump lol. Nobody needs these? Hard to come by.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Bump again. Hate to toss OEM parts. Free, buyer pays shipping.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Is this ok?
Bronco648
102
XL
2.3
15"
@bronco2fan I'll let Andy have the final word but that does not look like the 2150 I used. There's an awful lot of electronics on that one. Perhaps you can strip off some/all of those things (perhaps not). My carb didn't have the mechanism to the right of the fuel filter (and below the bowl vent). It did not have any of the electronics to the left of the choke. It did not have the pull down (just visible above the choke linkage, on the back of the carb). 2150 carbs from 70s Mustang II and Pintos had more simplistic versions. Yours looks like something from the mid-80s (no offense - if it's from an early Ranger, that would explain it).
If you can get a better pic of the carb tag (or post the numbers/data) that will help Andy. Also, you want a 2150 with the 1.08 venturis. That info can be found on the driver's side of the carb body, in front of the accelerator linkage. HTH.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
It's the original one from a 84BII, like the topic says, OEM. I replaced it when I did my Duraspark conversion years ago. Carb tag says E37E ABA. Side says 1.08. If the forum used tapatalk I could post better pics.
bubba79
4
26143
2.8 V6
171..+0.30over
4+4 susp.and body
12.50x16 agg.tries about 33"
What type of distributor if available still
Junk Collector
Truck of Month
4,806
Rapid City SD
"OEM Feedback carb and distributor" - I am sure he means that it's the one that came in the truck, the stock TFI style, NOT the Duraspark one
bubba79
4
26143
2.8 V6
171..+0.30over
4+4 susp.and body
Thanks but I'm either going to stay dura spark (if can find one ) or gonna go to points
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Here's the bump again. I also found a set of bolts, washers, nuts for the 2 inch body lift from James Duff. 2 poly control arm bushings too.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
