OEM Keyless Entry On a '93
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
I'm converting my manual doors to power doors and once that's done I want to get keyless entry, but an OEM one. Reason being is I just want to have everything OEM as possible for the year. In the brochure they have a keyless entry system, but I don't know if it ever went into production. If so, anyone ever have it? Maybe part number?
43741
I have seen other OEM modules, but for either the probe or other ford trucks, but not specifically the Ranger. Question: are OEM keyless entry units made specifically for certain models, or are they basic enough to be interchangeable? If not interchangeable, is there one for the ranger?
43742
3,614
I've never seen fobs like that.
With enough ingenuity and wiring diagrams any RKE system can be put in almost any vehicle.
I had a functional RKE system in my 87 Ranger using parts from a 98 Taurus.
McWillies
9
Ford Bronco II
I had this same interest a while back but never dove any farther into it than plain research. I wish I'd caught this then because I could've given you a good bit of information. Either way, I was able to dig up a few links that may help you. From what I can recall as far as the compatibility, the system essentially had signal wires going to the power door locks and when the button on the FOB was pressed, the transceiver (I assume that's what it would be called) caught the signal and did processed it. Fairly simple system if you think about it as signal wires and a signal box.
A couple part numbers:
Anti-theft Security System -- E9AZ 19A361-X ("X" represents a single letter, A through G. The different variations came with small additions, like an extra FOB, siren, etc.)
Remote Keyless Entry System -- E92Z-54220K51-X ("X" has similar meaning as above.)
Here's a few links:
OEM Remote Keyless Entry Kit on Ebay -- Has the FOB with "L" and "U" buttons "lock" and "unlock."
OEM Security System/Remote Start on Ebay
Wiring Info -- Browse through the different vehicle's charts from different years, models, etc to gather information about how it all works.
Almost forgot to add this:
It's seems to show an optional security system being available for all 85+ light trucks. This is straight from the master parts book.
mtnrgr
766
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Have seen the remote in the first picture way in the past. When I worked at Ford years ago, knew the alarm guy there really well. From what I remember any Ford alarm can be used in any Ford vehicle. Same as walking to an audio shop and ask for a security system, yes they will ask what kind of vehicle you have...yet it can be installed. Any alarm system can be installed into anything. Give you props for wanting to stay 93 with everything on your Ranger.
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
Awesome! Thanks for the motivation, now i'm not limited in options here.
Here's a few links:
Thanks for the research! Since these are basic systems, it seems like the first link you posted is just keyless entry, but the second link that has keyless entry supposedly too, has arm/disarm for the security system. I presume these actions include lock and unlock? Too bad there isn't a brochure, or manual somewhere that explains this.
Also, the third link you posted doesn't work.
So the remote you remember was for the security system only, or did that include keyless entry. And yeah, interchangeability makes sense.
Thanks for the compliment! I'm trying here.. it's a scavenger hunt trying to lock down 27 year old parts haha.
snoranger
Professional money waster
ASE Certified Tech
13,731
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
If you want it to look period correct, this is the remote they would have used in 93...
43809
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
snoranger
ASE Certified Tech
13,731
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I figured that's the key fob they used in 95+, but i didn't think it was also used in 1993. Hmm...
It was the one that came with my ‘93 Explorer limited (bought used) and my parents ‘94 E150 (bought new, so I know for a fact it was original).
8,374
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
This is a 1993 part number for keyless entry unit F3AZ-54220K51-A
Seen here with wiring label shown: https://www.ebay.com/itm/NEW-OEM-Ford-F3AZ-19A361-K-Dealer-Installed-RKE-Remote-Keyless-Entry-Module/184109165084?epid=1517823151&hash=item2addc2ea1c:g:OJEAAOSwWSVeDkIl
Looks to have a starter motor "disable" relay that can be used, but not an alarm like some other keyless entry had
I assume the horn connection is just to confirm lock or unlock command "received"
Where did you get that part number from? The link provided is for a separate system, seems to be similar to 97/98 vehicles. I googled the PN you gave and it's for a newer system still?
https://www.fordpartsgiant.com/parts/ford-kit-repair_f3az-54220k51-a.html
8,374
Ford pre-1999 part numbers are like this
F3AZ-54220K51-A
E1 = 1981
E9 = 1989
F1 = 1991
F3 = 1993
ect...
And this is the year it was first used not the only year it was used, so you could find an F3 part on a 2020 Ford if it has not been changed significantly in that time
So F3 part may be found as OEM on later years
And in this case the E9 version may have been used in the 1993 Rangers, don't know, just found there was a 1993 version
A = generic, not model specific, 7 here would mean for Ranger model vehicle
Z = Ford service department, usually electrical
-54220K51- <<< this is the actual part number for keyless entry not model or year specific
-19A361- <<<looks like this part number was for keyless entry WITH alarm system included in the module
-A = version or kit designation
In 1999 Ford change the first 4 numbers a bit, first number alone is the year
X = 1999
Y = 2000
1 = 2001
A = 2010
B = 2011
L = 2020
Then the following 2 numbers are the vehicle model if its specific to that model
L3 = F150/F250
L5 = Ranger
R3 = Mustang
4th number is the same meaning, the department responsible for design and repair
And Part number and versions also stayed the same
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
F3AZ-54220K51-A
E1 = 1981
E9 = 1989
F1 = 1991
F3 = 1993
ect...
X = 1999
Y = 2000
1 = 2001
A = 2010
B = 2011
L = 2020
L3 = F150/F250
L5 = Ranger
R3 = Mustang
Wow got it! Thanks so much for the information, that cleared up a few things. Then yeah it's possible they added a new remote entry model for 93. I have to double check the security system. I have to write this stuff down for future reference! Thanks again.
8,374
Yes, it looks like Keyless entry came with and without alarm system in the module
But it looks like "Starter interrupt" was on either, just one more thing to go wrong, lol
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
The F3AZ-19A361-A version im finding is the security system and is considered as an Add-on to the remote entry, not combined. Thoughts?
8,374
Yes, that could be the case but have a read here: http://www.idmsvcs.com/2vmod/remotestart/index.html
This part was interesting
The powercode units have a seperate daughterboard inside them called DNA that contains the programming of the unit.
This allows for inexpensive changes of feature sets, for instance turn a keyless entry system into an alarm.
Note that each DNA cartridge has it's own unique menu of programming options.
Also note that there are two different revisions of the main control assembly, one allows for only alarm & keyless entry functions. The other allows for alarm, keyless entry and remote start features.
