Oh, LOOK! Not ANOTHER V8 build thread!!!
Thed
19
Raleigh, NC
I forgot to ask... Will I need a new oil pan? All of the info surrounding oil pans is kind of fuzzy. :icon_confused:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
No, the ex oil pan fits both TTB and sala suspension rangers. You will need an oil filter relocation kit with the 90* block adapter...
SVT
Thed
19
Raleigh, NC
SVT
Thanks again, man. :icon_cheers:
I already knew about the oil filter relocation kit, though. Jegs has a kit for a 302 swap in a Ranger and I dismissed it when I saw that the oil re-locator stuck straight out of the block instead of the 90* bend. Not good.
Also, L&L makes an engine mount kit for $175. Looks like it is of pretty good quality. I would consider ketting this...
Thed
19
Raleigh, NC
Looking at it more, though, it looks like it uses V6 mounts as a base and then the adapter goes on top... lurrdddd things can get tricky.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Don't waste your money on that. Use your factory 4.0 rubber mount and just fab a plate to bolt to the block. If your not up to it, I can fab you a pair. This also allows you to get over the counter parts if you need a motor mount, unlike the custom mounts everybody else has...
SVT
Thed
19
Raleigh, NC
SVT
Two things about that... I got a 4 banger, not a 4 liter. But I just looked it up on Rock Auto, $13 each. So no prob there. Also, do the custom ones that you make sit lower than ones if I were to buy one from say AA?
And two, how much do you charge? :icon_thumby:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
The way I make em is about as low as it will sit. The block bosses that the mounts bolt to sits 1/4" higher than the top of the rubber 4.0 mounts on the passenger side, the driver side sits about 1.5" above mount (to level the motor). I can fab the plates for you for about $25 a pair (basically covers materials ) plus shipping...
SVT
Thed
19
Raleigh, NC
SVT
Best deal on the internet man, PM me and I'll PayPal you. :icon_thumby:
Thed
19
Raleigh, NC
Also, radiators. I read somewhere a radiator out of a first gen 4.0 Explorer will bolt right in but I highly doubt that it has the cooling capacity for a 400 HP engine...
I don't really want to shell out $600 for a radiator when the damn engine cost $400
I'm going to learn welding by the end of the year so any suggestions will be helpful.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
I'm running my stock 4.0 rad in my 96 ranger, and the stock 5.0 rad in my Trac. I don't have cooling issues with either. Just make sure when you do yours, that you cover enough of the rad or make a shroud...
SVT
Thed
19
Raleigh, NC
Huh, then I guess I'm going to be hittin' up LKQ again. I'm thinking of doing a cold air intake with a ram-air hose going up to the filter from down low, so that should keep intake temperatures down.
Thed
19
Raleigh, NC
Update
The T-5 idea is looking like a bad one. I'm just going to play it safe and stick with the M5OD-R2. Nobody wants to ship this bitch though.
hopster
9
Bedford, IN
2.9, 4.0, 5.0 can't decide
i'm gonna do a 5.0/m5od in mine soon. while lookin for one try to get one from 04 heritage or older to avoid other issues. i believe the best ones were 97-04 heritage v-6 f150. i planned on using cluth components from a 96 f150.
hopster
9
Bedford, IN
sweet how long til it gets there
