crazybronco
- Jan 21, 2009
- 0
- Roy Washington
- Ford
- Engine Size
- 2.3l
I was having a leak problem on my BII with 2.9L and so I replaced the valve cover gaskets. It was leaking down on to the exhaust and then smoking. After I installed the left side I fired it up and checked for leaks. With everything clean I could see oil pushing its way out around the valve cover bolts. What is up with that????
I pulled the bolts out, cleaned the bolts and holes real good, then reinstalled them with RTV around the bolts and hold downs. It seems to have stopped the problem, but why would it do this? Is there a oil galley near them? Or, could it have been oil down in the hole that was being forced out as the engine heated up?
I still need to do the other side, so I would like to know before I do it.
Any ideas?
Any ideas?
