Oil pan clearance
allpau2thou
Haleiwa, Hi.
1991 5.0 H.O. carbureted
I never notice till I pulled te motor out but my Stock I beam has been hitting my oil pan. I can post a pic later. The engine is as high and far back as I can get it. Any suggestions how to resolve this? Was really hoping to drop the front a couple inches but that would only exaggerate the problem from what I can imagine.
chrwilkins30
6
Mishawaka, Indiana
How can that be when the beams run under the engine cross member protecting the oil pan.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Your motor is contacting your engine crossmember, check your motor mounts and see if they are torn or ripped. Also, what oil pan are you using? What motor mount setup you went with?
SVT
morse johnson
i came across that problem with my 91 ranger. what i did was used a flat plate 1\2 thick i mounted that to the frame and slotted it so my mount would slide down into it. my motor mount was from a 93 convertible
allpau2thou
Haleiwa, Hi.
My adapters look like these (Trans Dapt P/N 9716) and the mounts are from the 91' F150 my 302 came out of. It's not hitting the cross member just the I beams. The I beams aren't underneath the cross member on my truck, they're kinda parallel looking down on them. I'll post a pic if I can...
allpau2thou
Haleiwa, Hi.
You have to modify that mount at all? Did it require any kind of adapter?
morse johnson
i didnt have to modify my motor mounts at all..on my plates they were 1/4 and not a 1/2 my mistake. here is a picture of how my motor sats and the next picture is how my plate was made to lower my motor.
bearsrngr
5
Wayne Nebraska
The right hand I beam is behind the cross member and will contact the 6 quart oil pan used in the F150s. You can modify it to clear or use the crown vic/mustang dual sump pan.
allpau2thou
Haleiwa, Hi.
I have a dual sump pan. Wasn't sure if the front was to tall? Thought it would hit the cross member... Wasn't going to use it. It's really nice. Polished steel. I'm getting a 5.0L HO from a 91' Mustang. Will the pan on it work or should I use the dual sump one?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Fox mustangs use the dual dump pan...
SVT
85_Ranger4x4
17,953
SW Iowa
I am not pleased at all with the fitment of my dual sump pan. One side took 1/2" of washers and the other side took 1/2" of washers and 1/2" of plate to get it so the drain plug wasn't sitting on the pivot bracket. And then I had to hacksaw the new drainplug off to get it out and hunt for a shorter one at the first oil change.
But 4x4's are different than 2wd's...
allpau2thou
Haleiwa, Hi.
Has anyone used a dual sump pan in a 91 ranger without any problems? With what engine mount set up?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Hit up iron ranger, he has a gen2 ranger with a 5.0, I believe he used the dual dump, but he is 2wd...
SVT
purplehaze
oneida tn
351,gt45 turbo,blow thru
I'm using a dual sump and also had the ibeam scrap the pan when the fronts springs compress. It barely rubs the pan, I took a angle grinder and shaved the lip on my ibeam until it cleared the pan, I say about 3' long section the thickness of a music cd is all I had to remove. I'm using adapter plates and stock v6 mounts and 3'' drop beam also.
allpau2thou
Haleiwa, Hi.
I'm hitting pretty hard, and it's without the front dropped. I'm going to have to figure something else out. I'm suprised I didn't bust the pan open...
