Oil pan clearance?
SheepDog
So thanks for the help in the other thread, got my ranger up and running again. As I mentioned in my last post, I have discovered that I have a coolant leak and I narrowed it down to the timing cover. It is leaking on both sides of the cover as well as out of some of the bolt holes.
I read in my Haynes manual as well as many places online that in order to do the timing cover, the oil pan is recommended to be removed. But the manual and everyone else says that the motor needs to be raised and/or tranny removed to get the oil pan off due to clearance issues with the frame.
I was looking at mine today, I have the 2WD Edge package with the torsion bar setup. However, there is TONS of room between the oil pan and frame, at least 4 to 6 inches where the front of the pan is right over the frame bar. The rest of the pan is open and can literally drop straight down.
I see no reason the pan wont come right off, no engine lifting or tranny dropping needed. Am I missing something obvious here? I was apprehensive to so this job at first but now it looks pretty easy unless I'm not seeing something.
Sidenote, I wish I would have known this leak existed when I was doing the head gaskets, would have been much easier to do the timing cover job at that time. Now I have to tear the front of the engine off all over again.
cbxer55
767
Midwest City, Oklahoma
Maybe the torsion bar version isn't a problem. My 2 wheel drive has the control arm front (just put all new everything on Wednesday), and I've put up with a small drip from the oil pan for years because there ain't no way the pans coming off without lifting the motor.
SheepDog
Ok, thanks guys. Guess I have the only version of the truck where the oil pan just comes right off, lol.
Looks like I have a project next weekend!
SheepDog
Never mind, i need to jack the motor up. The stupid oil pick up tube hangs down so far into the pan that I cant get it off. The front of the pan does indeed get stuck on the crossmember...
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
unbolt the tube.
SheepDog
Got it taken care of. Ended up just unbolting the engine and transmission and jacking the whole power train up about 6in. Wasnt too bad at all.
Rearanger
23
Southeast USA
Just for my future reference, did you need to disconnect any AC tubes, electrical wiring, cooling hoses to jack 6"?
