TEACHER
- Dec 18, 2018
- Reaction score
- 2
- Location
- Alabama
- Make / Model
- Ford
- Manual
1994 4.0 I have put my oil pan gasket on 2 times each time new gasket and it leaks. This time I used a fel pro gasket and mounted it to the block first. I put the rubber ears that are on the gasket that go to the back of the block in the slots were the #4 main cap makes the hump at the back of the engine. Should I be putting it on the pan first. I try not to use alot of silicone but I do on the corners of the front and rear of the block. Also I am totally redoing this truck. I have the core support out for paint and ease of pulling out the engine. This is 4x4 so should I remove the engine or transmission. I do not want to take the heads or headers off this engine again. Would it be best to remove the transfer case ,then tranny if that is the route that is suggested. Thanks in advance I know this is alot.
