Oil passage schematic
1930
Brandon/Ocala Florida
Hello, 98 4.0 OHV, can't find it on all data and Google isn't my friend.
Can someone provide this too me. Thanks
8,372
Welcome to TRS :)
I don't recall ever seeing one for the Cologne V6 engines
1930
Thanksgiving for the reply.
So specifically how does oil get too top end?
8,372
What is your specific reason for looking for this info?
I know that oil going to the lifters goes through the cam bearings first. Worn cam bearings were a common cause of lifter tick for the 2.9.
Like Ron, I am not certain of the path the oil takes to get to the rockers.
1930
I'd like to know so that I can address any issues that may come up with oiling but mostly at this point cause it seems no one else knows which amazes me
I have a 4.0 in my ranger, it's fun to understand how things work
1930
The center pillar on rocker assemble has an oil passage that comes up through the head
Seen here: http://www.alliedmotorparts.com/media/catalog/product/cache/1/image/650x/040ec09b1e35df139433887a97daa66f/a/l/all12960-1_1280x851__1.jpg
Not sure where that passage in the block starts off?
The pushrods are solid so no oiling from lifters
That hole runs over to one of the head bolt holes so not sure how that would help.
Also the bottom of the pedastal does not have a corresponding hole so it would seem to dead end at the bottom of the pedastal.
I've got great oil pressure and lots of oil on my top end but I just can't figure out where it's coming from
The 4.0 is a stroked 2.9. Oil flow through the system should be very similar.
saskbill
6
Saskatoon, SK CANADA
Also the bottom of the pedastal does not have a corresponding hole so it would seem to dead end at the bottom of the pedal...
On a 2.9, the oil flows up through a passage in the pedestal and through the hollow rocker shaft to the rocker arms. As noted by adsm above, worn cam bearings starve this oilflow before it reaches the pedestal. Also, crud accumulating in the hollow rocker shaft(s) can impede/block oil flow to the valves. If the 4.0 is similar, maybe someone else can chime in.
https://therangerstation.com/forums/showthread.php?t=9361
1930
No passage in pedastal, the only possibility is that because that hole mentioned above is flared out into the pedastal bolt holes that oil is supposed to squeeze around that bolt up into the rocket shaft.
Looking at it again I guess I've answered my own question.
Silly design if that's the case
TxGasRacer
SE Texas
4.0 ohv
The OHV 4.0 is a great engine and is German Engineering at it's best
The 4.0 is known for oiling issues at the rockers. That's why the pushrods "football".
