Oil Pressure Gauge Jumping
Kroeter
Ohio
V6 4.0
My oil pressure gauge likes to jump back and forth between low and normal
Truck is a 97 with 4.0 in it. The truck runs fine and shows no difference when gauge is jumping. I'm thinking bad gauge or sensor. Not too worried since truck has 270,000 and still runs OK. just checking to see if anyone has any idea
Thanks
tinman_72
136
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
It is common for the connection at the sending unit to get oily and loose and the gauge will do just like you described. Try disconnecting it, cleaning it up and make sure there is a good connection.
