oil pressure sensor location
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
Anyone know where the oil pressure sensor on a 89 2.3 is? Having problems trying to find it. There is just to much stuff in the way under the intake to locate it.
The gauge has stoped working and I need to see if it is the sensor, gauge, fuse,or I just lost all oil pressure together.
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
directly behind the #4 intake port and slightly below.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Ok, I figured that was the water temp. Thanks for the help
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
water temp is just above and behind the oil filter
escort_gts
16
Fort Wayne, IN
4.0, 5.0
ok, how about the water temp switch?
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
that is the gage sensor, the computer sensor is on the top of the intake manifold by the fuel injectors.
dubluvv
Are these locations the same for a '91 2.3L? I just bought a oil pressure and water temp gauge kit and am looking to hook them up.
Thanks!
Mitch
steve63
marysville,ca
2.3
there at the same places on my 90,so they should be pretty close as 89-92 are very simular.
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
the locations in the block/head for the gage sensors are the same for all 2.0/2.3/2.5's
escort_gts
16
Fort Wayne, IN
4.0, 5.0
is it the one that is on the number 1 intake, or in the middle between 2 and 3?
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
on an '89 there should only be fuel injectors and the coolant sensor on top of the intake manifold by the injectors, it's a white connector, round with a little corner (kinda like a tear drop I guess). I'm using a '86 turbocouple manifold or I would look for you...
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Ok, thanks for the help.
No members online now.
