American1990
- Dec 10, 2010
- 0
- Conyers, Ga
- Ford
- Engine Size
- 4.0
- My credo
- Build it, Break it, Re-build it stronger.
Read everything before you THINK you know what it is!
~Cant get clutch top disengage/put truck in gear~
Ok, so here what going on... if i start the truck up in gear it takes off like a rocket, but if i start it in neutral I can not shift into any gears it will not let me.
So here what been replaced so far... Slave cylinder (4 different ones 2 of them brand new), Master cylinder, pressure plate, throwout bearing, clutch disc, motor mounts, new cross member (old one was bent), and 3 different transmission have been put in.
What has been done, hydraulic system has been taken out and bench bled step by step by perfection clutch to where there less then 1/8 movement in the master cylinder and brand new fluid. Slave cylinder bled also correctly. Underneath the truck i can see the slave push up against the pressure plate. I am 100% there is NO air in the system and it is working correctly.
(WHILE THE TRUCK IS ON) Ok now THIS is where things get WEIRD and tricky... IF I lift the rear end off the ground (Lifting from the frame not axle) I can shift with just a little resistance into any gear, If I lift from the axle to where only the wheels are off the ground i can shift but I have to push it with some strength, IF I have it on the ground and I put the transfer case in neutral i can SHIFT into any gear like it butter, also if I just have the transmission Hooked up without anything I can shift with ease.
Also, if I have the truck off and in first gear (or any gear) if I press the clutch or let someone else hold it down i can not move the truck...
I am 100% sure there is no air in the hydraulic system... I bled it perfectly and got every little bit of air possible.
Ok, could there be some kind of drive line b ind up? or the transfer case is some how the culprit? after I hook the transfer case up (with just the transfer case hooked to the back of trans) I can still shift but that where it starts to get resistance in putting it in gear, not A LOT but it starts...
IDEAS??? thinking either transfer case, read diff, or springs are so worn out it messing up alignment...idk, just shooting int he dark here!
