decolores9
- Mar 18, 2011
- 0
- Ford
2000 Ranger 2WD 2.4L, started throwing a P0455 code. I have replaced the gas cap with an OEM replacement, the filler and vent hoses from the filler neck to the tank, cleaned up the filler neck (does not seem to be perforated), and the solenoid and the hose from the cannister to the solenoid. Thought the solenoid fixed it, but the light came back on this morning.
Any suggestions on common failure modes, things to check, how to diagnose the cause? I'm thinking of disconnecting the vent hose at the filler neck and using a hand pump to pressurize the system to see if it holds. Unfortunately I don't have a smoke machine.
Thanks.
Thanks.
