PATS programming with Forscan
Sorry, I should have quoted Otis when typing my response. The comments were geared towards his post and how to proceed.
Ah. They do apply equally well to both situations.
Otis413
117
Cass, WVa
4.0 SOHC
Thanks for the info guys!! :icon_thumby:
Now if the rain would stop for a while I might actually get that '04 on the road!
dosercody
California
Have the exact equipment as the poster. I've gotten to the point where you erase the keys and security access is denied. Anyone had this problem or fixed it? Trying again just to see... (hopefully this old post isn't dead in the water!)
fastpakr
2,834
Roanoke, VA
So it shows the modules and you click the wrench icon. At that point does it give you timed access or do you use the incode/outcode process?
dosercody
California
Timed access. I did get it to complete on the third try. Now I have both keys erased, byt new keys seemed to not program properly. Waiting on the new Timed access to get through to see what happened.
fastpakr
2,834
Roanoke, VA
If you had two keys to erase, why are use this procedure?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Im confused as well. If you have two keys you don't need forscan to add more.
dosercody
California
Not sure where the confusion is at. If I had to erase two keys, that doesn't mean I HAVE two keys. I had/have one, and needed to replace the ignition cylinder so went ahead and got new keys.
dosercody
California
