silkysix
- Jan 10, 2009
- 0
I am building a 4WD BII. The 2.9 I am puting in it came from a 2WD Ranger. When I picked up the flywheel from the machine shop the pilot bearing had been removed. That is okay since I would replace it anyway! The problem is: The new pilot bearing I have appears to fit into the crankshaft but is way too small to fit into the flywheel. The input shaft on the tranny does not extend forward far enough to fit into a bearing pressed into the crankshaft. Is there a difference in flywheels for the 2WD and 4WD? Is there an alternate pilot bearing?
