Plastic piece that engages T-case shift fork
Hawkeye58
Las Vegas, NV
2.9 L
Hi all,
Anyone here know where the nylon/plastic piece that rides on the end of the T-case shifter can be found?
It looks like the shape of two washers sandwiched to a square nut in between them. This part engages the shift fork on the t-case. Mine is brittle and has shattered the sides off and now is pretty much just the square part left. I want to find a new one if possible. The ones at the bone yards are either, missing or, broken like mine. Any help is greatly appreciated. Thanks.
Hawkeye :icon_thumby:
I got a bunch of those plastic crush rings that go around oil drain plugs and used them to shim it up. Worked pretty well.
PlumCrazy
2014 Truck of The Year
178
Millersport, OH
Solid Axle Swap 4x4
I took a nylon bushing made for clutch pedal linkage and ground a flat spot on two sides so it would fit in the end of the fork, then put a washer on the outside. I also cut threads into the end of the pin so I could thread a nut onto it.
-PlumCrazy
Downey
Muncy, PA
i dont have one one my truck and it shifts fine
lil_Blue_Ford
6,185
Butler, PA, USSA
4.9L
-PlumCrazy
I don't suppose you have a part number handy or know what vehicle it was for?
PlumCrazy
178
Millersport, OH
Solid Axle Swap 4x4
It came in a variety pack from the Help section at Advance Auto.
-PlumCrazy
Hawkeye58
Las Vegas, NV
2.9 L
Great ideas guys. I'm guessing then there isn't a source for the stock part or an after market one. So, I'll use your ideas to get something put together. Thanks for the help!
