Plugs for exhaust manifold
idahobob
idaho
I have removed the large steel tube that runs from the intake to the exhaust and the shorter one that runs up to a diaphragm that was connected to a hose. Any idea what size and threads these are? One appears to be straight and the other tapered. Are these British Parallel and British tapered? Did the Japanese use American Standard on these trucks? Just thought I would ask before I start running all over town looking for the plugs.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I believe those are standard pipe thread. Caution, that is for the EGR system. If you are subject to emissions testing, that could cause a fail and may cause legal issues. Every State is different, so this is only a caution and not a judgment.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Egr bung on my headers was m22x1.5 IIRC.
idahobob
idaho
No problem here. I appreciate the input
9
St Petersburg, FL
2.3
Im tyring to find an EGR plug and plate to for my 91 Ranger 2.3 I swapped engines and the one I got came with EGR trying to plug it.
idahobob
idaho
I built my own plate and made a gasket for the intake manifold. The other end is a m22-1.5. Ended up buying a plug for it. Since it is a tube connection a pan plug didn't work. I also used JB weld for thread sealer. The other hole in the exhaust will take a 1/2 in pipe plug. Again, I seed threads with JB weld.
