Power Door Locks have a mind of their own
Gysgt-13
St Louis
Ford Ranger XLT
My 01 Ranger XLT has developed an issue with the power door locks. It acts like someone is playing with the key FOB. The doors will lock, the horn will chirp and the parking lights will flash as when the alarm is set. It will do this periodically on it's own, day or night. Any ideas?
snoranger
Professional money waster
ASE Certified Tech
13,687
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I had a very similar issue on my '01 (all the same symptoms plus unlocked when you closed the door)... It was chafed wires inside the rubber boot between the cab and door.
Gysgt-13
St Louis
Ford Ranger XLT
Thanks for the reply. I will check that and post my findings.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,514
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Ya know... not saying I've seen this on a Ranger but I have seen water intrusion on a door lock switch do similar things. It could also be the switch is worn out and causing lock activation. You might try just disconnecting the door lock switches... one at a time... and see if it stops acting up.
