Junk Collector
Truck of Month
- Mar 4, 2008
- 4,860
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
Pull the box, route both lines into a drain pan, unplug the coil pack and crank the engine over for 10 seconds or so. Let any left over oil drain out and then put it back together. If you really want to get crazy with it you could remove the lines and flush them and the pump out with brake cleaner but I think that's going a little overboard.
