Project #11 - new daily driver '94 Ranger
mtnrgr
758
California
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Your ranger is turning into a good looking truck. I like the progress that has been done.
Junk Collector
Truck of Month
4,802
Rapid City SD
Thanks, just wait till I get a 5 speed, manual t-case, 3.73's or 4.10's, about a 3" lift, 31's, different wheels, headache rack with some lights & a tool box... My wallet is already hurting lol
mtnrgr
758
California
31x10.50
I like that..sorta a twin to plumcrazy's truck minus all the dents.
Junk Collector
Truck of Month
4,802
Rapid City SD
I'm moving some tires around - if you follow my other builds, you may recognize these, so just a hint that there will be a small surprise coming next week.
This truck needed tires pretty bad, the rears were at about 15% and the fronts were better but weather checked enough that I don't want to run them on a daily driver. I was a bit nervous about how 31's and 3.27 gears would interact but it's actually not terrible. Probably just speed up my 3.73 swap a bit. 31's were the ultimate goal on this truck and these tires are pretty old so I figured I'd burn them off rather than buying a new set.
While I was swapping tires last night, I found some slop in the wheel bearings. The previous owner told me (in the same sentence) "I just redid the front brakes" and "I'm not mechanical at all but I can handle that." So I immediately assumed that it was not done right and of course I was correct, the nut was quite loose on both sides. Since my 2 door Explorer is being disassembled I decided that I needed to swap in manual hubs and that made for a handy donor. I'll need to go back and clean out the bearings & repack them with fresh grease - it was obviously mixed with old dirty stuff too - that can wait.
I also bought a Raptor Liner kit so sometime this summer I'll be doing that.
