- Oct 27, 2007
- Reaction score
- 16
- Location
- Fort Wayne, IN
- Make / Model
- Ford
- Engine Size
- 4.0, 5.0
- Manual
It all started with my brother riding along with me to Bundy Hill in Michigan. The next weekend he bought this
It was a 89 Toyota, not street legal with a locked rear. He played with it for a few weeks around his property and it needed some work. Had broken leaves on both sides and the PO had fixed the frame...
He wanted something street legal he could drive and also wanted a solid front axle...he found this on Craigslist
An 85 Toyota 4x4. Had 31x10.5 street tires and a rebuilt engine. Went with him to bring it home. The next day he found some rust in the frame, ended up being worse than the seller stated. I sold him the 35" Mud Kings I had on my ranger. He put them on with some Chevy wheels. He also put a cap on the back.
Next to my truck.
Here is the spot of rust, we thought this was all there was...
We made some plates to fix and reinforce the frame...
After these pictures he went and plated the rest of the frame...
He decided to make the bed shorter and move the tube bumper 10"... we cut if off and and relocated it
At this point he was just going to make a tube/flat bed
This picture you can see the rest of the frame plated.
He then decided he wanted the truck to look stock and wanted to put the bed back on but shorten it by 11.5".....he didn't want to cut all the tubeing that he welded to the frame so he could easily tie into it when he makes the roll cage. He wanted to just lift the cab two inches to match the bed with the 2" swuare tubing on top of the frame...I said just cut out the bed floor and and make removable bed sides.
So this is as far as of today. He has new brake line ran and mounted a small gas tank to the frame for temp. He will be getting a 20gal fuel cell.
We will be swapping rear leaf springs with 64" chevy springs. My friend own a fab shop and has a plasma table, he made these front spring hangers.
I will update this as I get time. We have worked on it everyday for the last month
Next to my truck.
