Project 85 Yota
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
We went out and played in the mud/woods twice this week.
This some of the stuff we were driving through.
We need to swap the leaf springs. He has no flex at all. The rear tire is 5 inches off the ground.
We were on a trail made for quads, it was tight in spots. A tree didn't like beeing ran over.
It's actually worse than the picture shows.
Sent from my HTC EVO 4G using Tapatalk 2
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Finally, we are going to finish his Toyota. He wants to make a trip to Bundy Hill in Michigan next month. I'll try to update this when I get time.
Things to do:
63" Leaf spring swap in rear,
IFS steering box,
Shock hoops for rear,
Finish plating the frame,
Longer shackles in the front,
Hope to get all this done in one weekend.
Sent from my HTC ONE S using Tapatalk 2
RangerBoy94
24
Northern California
360CDI
God that suspension sucks. My stock 80 yota flexes better than that. Probably some shitty skyjacker leafs on that thing. Up grad to some trail gear leafs they flex like no other. Ditch those lift blocks too. And the shackles will help alot If he hasnt already ordered a pair get a set of greasable ones from marlin crawler.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Yes it does suck. Lol
Swapping to Chevy leaf in the rear will help a lot. We have a set of 7" shackles for the rear from trailgear that we will put on, and we are having a set made for the front.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Work starts on the yota this Thursday.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Started working on the leaf springs. Have to remove the stock bushings where the shackles will be. Going to be using the real gear bushings that came with the shackle kit. I'll post pictures later.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Went with my brother to pick up hos new tow rig....94 GMC suburban for $1200. Just needs a little work. Pics later.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Took the beds sides off and the bed floor.
Removed the axle. When we lowered the axle, the springs pack came apart, the center bolt was rusted away.
Tomorrow we will start on cleaning up the frame. Remove the stock spring hangers and prep the.frame for more plating.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Got the frame all cleaned up and ready to start welding plate to the bottom of the frame to fix the rust problems. And tomorrow, we start welding.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Done,with exception of rear shocks. I'll post pictures later.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Small update. Made a front bumper. We started on it a month ago and then it sat until today. It will hold a winch and will finish it when he gets one, but for now it is done.
Not to bad really since it was all made with scrap steel pieces.
Sent from my HTC VLE_U using Tapatalk 2
RangerBoy94
24
Northern California
360CDI
Looks good. Whens he getting highsteer and dual cases?
escort_gts
16
Fort Wayne, IN
4.0, 5.0
He needs to find a new motor first. This one is eating rod or main bearings. Tons on shavings in the oil.
As slow as this build is going, it might be a few years before he gets highsteer.
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
If he needs a motor why not toss a 302 in with a np435/zf5 and skip the doubler
