ecgreen
- Sep 21, 2018
- Reaction score
- 287
- Location
- Dunbarton NH
- Make / Model
- Ford Bronco II
- Engine Type
- 2.9 V6
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 33
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
It always does...lol Well done!Picked up a set of radius arm drop brackets, that should correct the front axle and even out the lift level I think. I'll continue posting progress when I get the chance.
In the meantime, I noticed all my original progress pics were gone, so here they are again:
It started out as a MUCH simpler project than what it's become lol
Next question...any pics of the snorkel install? How did you hook it to the air box?Cool project so far!
Thanks for the pics!As promised, here are pics of the sealed setup underneath the hood.
I would imagine this would be similar on a fuel injected engine, just to a throttle body instead of a carb plenum.
Been having some issues getting everything level on the lift.
The original lift was simply a 2.5" front coil spacer, and a 2" rear block. My "just add an inch and a half" plan didn't really work.
The first shot is 3.5" rear blocks, and the front has Rough Country 1.5" leveling springs, plus the 2.5" spacers. The front still sits lower.
The second shot is still 3.5" rear blocks, but the front now has 4" skyjacker coils and a small spacer to make sure the 32" tires clear at full lock. The rear sits just a little lower, but we still have to put in a 6 degree shim to get the pinion angle right, we are hoping that gives the rear just a little boost to level it out.
This is a comparison between stock, 1.5" leveling, and 4" coils. Also the original spacers and the new short spacers.
I have not, but I'll have to keep that in mind! I think we're pretty much level, just getting the rear driveshaft figured out now...Have you thought about using some Belltech shackles on rear for 1-3" adjustability?
