- Feb 28, 2001
- 4,551
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
It's probably easier to count the things that don't leak than what does, so it's time to pull the turbo engine out, it's an oily disaster under the hood... The things I have planned or am thinking about doing:
-front, rear main, cam, aux shaft seals, pull rear main cap and reseal the corners like someone was mentioning and fix my oil pan seal trough fix from before, thinking lead this time instead of JB weld...
-cleaning EVERYTHING
-swapping over to my replacement Saginaw power steering pump since half the oil that's everywhere right now is power steering fluid.
-put my replacement heater box in and modify it better this time, and attach the heat shield better...
-Thinking of pulling the head, doing a bit of port work (at least gasket matching) and throwing one of the copper head gaskets in, while I'm there pulling the pistons to hone the cylinders and install a new set of rings, questions I have on this are what rings, and anyone have a good place to get the fancy head gasket?
Worst case is I find something wrong with my block, luckily I have 2 spares including pistons...
Anyone have any other things to do while I'm there? Of course I'm going to check all the turbo oil and coolant lines and check out the turbo (contemplate a couple things there too, have two more turbos to look at in the garage), thinking of making myself a catch can to help fix the PCV system. The oil pan and valve cover gaskets were new when I put the turbo engine in 3 years ago so they should still be pliable, if not they will get replaced, will just replace the timing belt while I'm there, they're cheap...
