pulls to the left when you hit the brakes (yes it is aligned)
jrpdash9
eau claire pa
ok my ranger has always done this but its getting worse. it pulls to the left when you hit the brakes or when you just let you hands off the wheel. ive had it alined twice. anyone know what it could be
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Replace your right brake caliper and rubber brakeline. The caliper isn't working and the left is. That is why it is pulling to the left. Might want to replce the pads while you are at it too.
fastpakr
2,841
Roanoke, VA
That sounds like a leap when it's also happening without braking at all.
Bad radius arm bushing?
jrpdash9
eau claire pa
i replaced both front calipers and pad ( long story had brake trouble) and hum ill have to look at the bushing dident think of that one
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Wait a minute....I thought the radius arm bushings were gone in 98?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
If it was a radius arm bushing it would not have aligned right. It would have come out when the front tires were swept side to side. I'm sticking with a deteriorating brake line. If both calipers were replaced.
James86
10
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
Check your air pressure. Mine pulled funny, especially when braking, and about a 10psi difference will do it. Stupid corroded alloys....
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm not familiar with these newer trucks but I'll make some guesses;
Caliper piston sticking?
Pins or slides on caliper sticking, needs lube?
Wheel bearing loose?
Good luck,
Richard
jrpdash9
eau claire pa
thanks guys ill check into the brake line and tires. i know my right tire always has a stupid leak it in. stupid alloy rims. but i always through it would pull to the right if that was the problem
