pulsing felt in brake pedal
donlightbody
Erie, CO
1995
2.9L 4.0L
88 BII power brakes rear ABS. when braking I am getting a heavey pulsating (only way I can think to describe it) maybe thumping feel, in the pedal. I can't recall 100% but I think it was there before I rebuilt the rear end when the idiot who pulled the bearing from the carrier broke one of the teeth off the ABS sensor ring. Might this be from the ring, or the ABS comp? Did the rear brakes for the FIRST TIME ever on this poor ole girl last summer, and didn't bother to look at anything in there when I had the drums off to do the rear end. Any ideas? Also, I need to change the brake fluid (completely) any tips there? I have a vacum pump, might help.
4x4RangerGuy
5
Newton Highlands, MA
Subaru
2.0
How are the front brakes? Pulsation in the pedal, especially when slowing down from high speeds, often indicates bad rotors.
donlightbody
Erie, CO
1995
2.9L 4.0L
front brakes are good. new rotors and pads spring 06. Looked at em a couple weeks ago and look good still.
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
dont just assume that the front brakes are good. if cheap replacement parts were used then there are no guarantees especially since they have only a 1 year warrantee or so.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
You can't really look at a rotor and tell it is warped.
donaldcon
19
Lancaster, Oh
loose wheel bearings will cuase it aswell.
Ranger5.0
Lindsay Ontario
id take a good look at the front breaks. If the wheels wernt torqued properly, it can warp the rotors, i dont se the tone ring causing an issue
donlightbody
Erie, CO
1995
2.9L 4.0L
k, I'll check those rotors soon as I find my dial guage. I really wish I could remember when it started doing that. Oh well. Will check it out. Thanks
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Pedal pulsation is a hallmark of warped rotors.
As for BREAKING a tooth off of the RABS tone ring?
I doubt it, those things are butter soft steel and breaking it would
be like breaking a gummy bear.
AD
