Question about a bed
I've got a 98 ranger with a 4.0 V6. 297500ish miles. I'm planning a trip down to a pull-a-part in Tampa (About an hour and a half away.) I've got a pretty good shopping list while I'm there. (Ashtray, passenger seat, dipstick, seat tracks, etc) I have a warped and dented bed. So bad I can't fit a tonneau cover on correctly.
My hope is that someone know how to take a bed apart so I don't have to rent a U-Haul to get the replacement bed home. I have a small 4x8 trailer I built from harbor freight that I take to the dump and I'd rather not take it all the way there.
I'd appreciate any input.
8,370
Ranger beds can't be disassembled, only cut apart and welded back together
But they are only held on by 6 torx 55 bolts and 3 screws on filler
Then unplug the rear tail light connector
Pull bed off and put replacement on
2 guys can swap beds, they are awkward but not that heavy
Wrecking yard should have no issue with leaving old bed there as they get money by weight of scrap steel
The replacement bed should fit upside down on the old bed, use 2x4s across old bed, and strap it down
Also can use stakes in the holes in bed rails to keep them lined up
Same as putting a canopy on the old bed
Heads up on tail lights
1993 thru 1999 Rangers used separate turn signal bulb/wire in tail lights, called "3 wire" system
2000 and up used combo tail lights, brake and turn shared a filament/wire, called "2 wire" system
So wiring is different
Lenses are interchangeable, so if you get a 2000 and up bed then you will need to change its wiring to the 1998 harness from the old bed, and of course use the 1998 lenses in the new bed
OR
They make trailer light converters, 3 wire to 2 wire that you could use to adapt 2000 and up lights to your 1998 wiring
Most like the look of separate turn signal bulbs
Thank you. I think that's exactly what I needed to hear. I appreciate the advice I wouldn't have thought to line the stake holes up.
