quick question
90rangerSTX
Northeast Arkansas
Im new to this site and i need some help,
i have a 1990 ranger STX 4x4 with the 4.0L, i messed the leaf spring, and i was going to take the leafs off the rear of a 2wd same body style(not 100% sure the year but same body style) and i wanted to know if they would fit on mine being the STX model, i know they have a little different suspension setup from the factory. im not worried about any streetable problems, my junk never sees the street unless its to get on the trailer.
greasemonkey6886
Sulphur Springs, Tx.
Welcome to TRS!!
Yes they should work fine. The only difference I know of on the STX was that they had a factory lift installed back in the early years of production. It was called a highrider but it was not produced in your year IIRC. Even with the lift it was only some bracketry changes.
90rangerSTX
Northeast Arkansas
thank you for the reply,
It shouldnt make a different that mine is a ext cab and the other 2wd model is a SWB?
greasemonkey6886
Probably a little softer spring due to less weight in the standard cab truck. It would be better if you could get a set out of another ex-cab or even better a 91-94 explorer(preferably 4 door). The explorer springs would possibly give you a little(1-1.5 inch) lift also. Look in the tech library, I'm shure that the explorer spring swap is posted there.
90rangerSTX
Northeast Arkansas
Ok I think I'm just gonna stick with the stock ones from a 2wd since I already have the truck. I bought belltch 6400 shackles for the rear,and for the front I'm gonna run a set of f150 coils that I have laying around. I'm just trying to do something quick for now so I can get it back out in the next few weeks.
Then with that 2wd I'm gonna convert it to 4wd and lift it and hopefully do a SAS
