QUICK QUESTION
Bear in the woods
94
Corinth Ms
Ford ranger XLT
2.9 in 90 , 4.0 in 99
30”
Should the yolk on a transfer case for the front driveshaft ..should it be able to just slip right out or is there a problem
snoranger
Professional money waster
ASE Certified Tech
13,724
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That depends on the year and which t-case you have.
85_Ranger4x4
17,972
SW Iowa
If it meets the t-case with a boot, yeah.
If the driveshaft telescopes in the middle (boot is in the middle of the driveshaft) no.
snoranger
ASE Certified Tech
13,724
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
On an ‘03 Tcase, you need to disassemble the case. The front output is held in by a snap ring.
pjtoledo
3,004
Toledo Ohio
Fords
3.0 2.3
what he said.
the yoke/CV holder are one piece with the front output shaft.
they can be replaced with the older style front output shaft, disassembly required.
don4331
1,354
Calgary, AB
5.3
Time out: Why are you wanting to remove the yoke?
There are 6 Torx bolts holding the CV to the yoke. The driveshaft show go from CV to u-joint.
Bear in the woods
94
Corinth Ms
Ford ranger XLT
30”
. Wrong picture of number. This one is correct
