radio antenna
ryan_88
hi, im new here. i've had a jeep for several years and just bought a 2001 ranger xlt yesterday. i have a sirius radio that i want to put in, and i am going to use a fm modulator like this
my question is, does the factory radio have a standard size motorola antenna plug like this?
or is it a small one that requires an adapter? also, how do i go about removing the radio? does the black bezel just pop off with a little force? thanks in advance!
ryan
dogboy
14
Enumclaw/ Carbonado, WA
'93
the plug on the back of my radio looks like that one.
If your radio is anything like mine, there will be two small holes on both sides. take a cloths hanger and do the following.
Once you have done that, take the u shaped wire and put it into the hoels on either side and push them in a ways and pull on the loops. The radio should come right out. If not, keep trying that way and you should get it sooner or later.
ryan_88
ok, thanks. so to get to the two holes, does the black plastic bezal just pull off, or is there screws somewhere that need to come out?
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
no you should see them in the front of the radio.
ryan_88
got it, thanks for the help
