Radio, OHC and Power Windows quit working.
GSUhooligan
Temple, GA
So, I finished the OHC and auto mirror install. I made sure everything was working for a day or two before I put everything back together. Everything was working, so I put the knee panels back. I think I may have pinched a wire when I screwed the metal panel back in b/c my radio, ohc and power windows are no longer working. I took everything back off, and saw the wire from the ohc to the radio had lost some of the protective rubber, but it was still intact. So I replaced that section of wire, but I still couldn't get it working. I checked the radio and PW fuses, and they are fine. Does anyone know what else I should check?
oldjohnny
4
Brazos Valley, TX
2.3L
Well, how did you ground everything? Don't tap into a ground, just drill a screw into the roof for the ground.
Also, where did you get power for the mirror? You may be pulling too much power if you tapped into the radio power for both the mirror and OHC. This may cause your fuse to go out.
GSUhooligan
Temple, GA
It was a GEM fuse. I didn't know there were two and the one I checked was fine. Thanks for your help OJ!
