- Jul 31, 2021
- Reaction score
- 672
- Location
- NW Florida
- Make / Model
- Ford Ranger XLT
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3
- Manual
- 2WD / 4WD
- 2WD
- Total Drop
- 1.5” till I get these springs replaced
- Tire Size
- 225-70-R14
I’ve run into several drainage problems over the years, most of which weren’t really solved cause you just can’t make water do something it doesn’t want. My current dilemma is a flooding back porch. It’s cut into a hill. Ground level is about +2’ at the far end of the porch and water drains to that side, away from the house. After a good rain, it’ll fill up and stay full for a couple days. The water table is far below (I’ve dug 5’ and was bone dry) and soil is sandy and just a tad bit dusty.
An actual drain pipe is pretty much out of the question. Would a wellpoint be a good option? I could knock a brick out of the retaining wall and drive a wellpoint there to get some surface area down in the ground for the water to soak in quicker. Would that make a noticeable difference?
