Random RPM surging
Wynco92
Utah
Ford Ranger XLT
I have a 1990 Supercab XLT that I have been restoring, Engine rebuilt, 5 speed Tranny rebuilt, All new parts on the engine. I am still breaking in the engine I have about 260 miles on it so far. I am experiencing random high rpm surges, sometimes when idling and often when I shift gears it will climb to 3000 rpm and slowly come down. This 2.9 doesn't have a Mas flow on it. any thoughts on the subject would be appreciated.
Bgunner
1,091
Western Mass.
Ford/Ranger XLT
225/70/R15
I am not all that familiar with the 2.9 so does it have an IAC? Idle air control valve. This could cause your issues if it is leaking. Call this a shot in the dark.
EDIT: just as a note for future ease could you go into your forum settings and add the 2.9L motor to your truck description so we can just look at your description of your truck and know what you have with out you constantly typing that you have the 2.9L in your truck. Thanks. :)
rusty ol ranger
2.9 Mafia-Don
7,605
Michigan
177 CID
IAC, TPS, or vaccuum leaks are the usual suspects on the 2.9.
Wynco92
Utah
Ford Ranger XLT
I have looked and can't seem to locate where to add to the forum settings?
8,372
Change PCV valve if its not new, its a controlled vacuum "leak", if it gets sticky then not so controlled, lol
Also on a 1990 the power brake booster is pretty old, so can be a random vacuum leak
Start engine, foot OFF the brake pedal
Shut off engine
Press brake pedal down 3 times, should feel power assist each time, then try 4th and 5th time should lose the power assist as vacuum is used up
If you are only get 1 or 2 presses then booster is leaking, may not be your idle surge issue but booster is leaking
Wynco92
Utah
Ford Ranger XLT
Shut off engine
Both PCV valves are new, however the Brake booster is not, I will look into that...thanks for the suggestion
JerrySab
44
Los Angeles
I had a really similar issue, with spiking RPM. Turned out to be failing TPS. It would spike to 3-5v with no pedal input, which would then cause resultant RPM spike. I had the benefit of decent shop nearby that discovered by using an oscilloscope. Easy fix but really enormous headache, as the TPS was relatively new. Wiring looked fine, computer looked fine, part swap solved the problem. Youtube link below is not my truck, but this was the gremlin hunting process.
Bgunner
1,091
Western Mass.
Ford/Ranger XLT
225/70/R15
Click on your name in the upper right corner, then click on account details, scroll down and you will see where you can add your trucks specs.
Hope this helps.
