Ranger 8.8/7.5 swap
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
I was reading about the 8.8 explorer swap, and i have a couple of unanswered questions. im not really concerned about the 28/31 spline difference, i just want the ease of a dirrect bolt in, as i dont trust myself welding on an axle. do the 8.8 ranger axles have disc brakes? how common were the ranger 8.8's, common enough to find in the junkyard? the major reason i want the ranger 8.8 is for the limited slip diff. for the winter months that are quickly approaching.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Yes the Ranger 8.8 is dime a dozen in the junkyards.
And 7 out of 10 will have Ford's Trak-Lok limited slip. I wouldn't trust a junkyard one to actually working like it should however, so buy a rebuild clutch kit as well.
As far as disc brakes, most will not. IIRC some FX level 2's might have had them...but like I am said I am unsure. Not having disc brakes is why many owners look for the explorer 8.8's since they have them post 1996.
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
i'd rather have the drum, dont really wanna run brake lines lol, im accumulating quite a junkyard list
Mac
183
C. Wisconsin
2000
199
I've found that less than 50% have the L/S but that really varys per area. Only Rangers that come with the disc brakes are the 2011. I'm also one that is happy with a good set of drums on a stock truck.
Dave
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
well maybe i'll get lucky and find one with 3.73's and L/S, if not im sure i can find one with the 8.8 and i'll just get a lockright
Original_Ranger84
20
Homer, Ak/ Anchorage, AK/Fairbanks, AK
2.8L, 3.0L
I got an explorer 8.8 with 3.73's and limited slip for 100 bucks and had the perches welded on at a shop for another 100 bucks. After that it shoudl just bolt in and you don't have to run brake lines for the explorer.
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
so once the perches are on theres no other really difficult modfication?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Dave
'10 and '11 have disc brakes.
Around my area the prevalence of limited slips seems about 30% or so.
The axle was made 2" wider in '93, so you'd want to stay with these axles ('93-'09) if you have a '98.
Original_Ranger84
20
2.8L, 3.0L
As far as I can tell I haven't seen anything that is major. Of course I haven't thrown mine in yet but the e brake cable might require a little mod like a hole drilled or something (not to bad), last I checked the brake lines were close and atleast no hardline mods, you have to get larger u bolts and spring plates and the shock mounts also need put on.
The only thing I am not sure about is the rear sway bar.
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
who needs sway bars? lol, but that dosent sound too bad, a project always seams more difficult before you start i guess
scotts90ranger
4,466
Dayton Oregon
2.3 Turbo
spring perches and shock mounts are required
BRONCONUT
4
Hartford, KY
'95~'00
5.8~4.0
If a person was going to go to all the work of swapping ales and moving perches and tabs for shocks I would go ahead and put in a 9" and be done with it. Putting the VSS behind the t-case would only take a few extra steps and cost a couple hundred more but in the long run you are way stronger and have no c-clip's.
I guess breaking so many 8.8's made me dislike them, any more if I am playing with axles I go bigger.
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
well, i would go 9", honestly though i dont think i'd ever break the 7.5, i dont do much hard wheeling, and i only do a little bit of light pulling, the most bennifical thing in my eyes would be how much cheaper gears and lockers are for the 8.8, and l/s would be the ultimate find
BRONCONUT
4
Hartford, KY
'95~'00
5.8~4.0
Fairly cheap if you ask me, you could probably regear front and back for around $500 if you install them yourself.
William Spitzer
Fulks Run, VA
1994
2.9, 2.3
i was orginally looking at getting a 7.5 lockright, but i figured for $400 one would cost i could save $200-$300 and pull a junkyard axle and bolt it in and go
