RustedRanger
- Mar 25, 2009
- 5
- Farmland IN
- Ford
- Engine Size
- 2.9L
Has anyone done things to make their Ranger more aerodynamic? I have thought about this from time to time as a way to increase gas mileage, since the Ranger is about a aerodynamic as a brick. I read once in a magazine about this subject as a way to increase top-end,like for the salt flats. It seems there would be a few things that could be done easily and cheaply. Something I remember mentioned about "flat" nosed vehicles was putting heavy screen across the grill,I have considered making a flat piece out of plexiglass to cover the grill and cutting holes for cooling. One thing I have been wondering about is hood vents,it seems they would really help. It would relieve the pressure under the hood and let the air exit over the top rather than under the truck and would increase cooling. If open holes were cut and screen installed a "pan" could be made under the hole to catch rain and snow and a small rubber hose could drain the water away from the engine. I have also read that an easy way to tell if you have helped aerodynamics is to coast a set distance from a set speed and time it,then do it again in the other direction.
