Ranger lean
MSGia
124
Central Florida
4, 5
Good evening all, had a question about the ranger lean. I wanted to lower my truck 4/5 but my truck leans to one side very badly. The fender gap difference from left to right is 1 1/4 inches, put some value below…
Driver Front: 1 1/2”
Driver Rear: 2 1/2”
Passenger Front: 2 3/4”
Passenger Rear: 3 3/4”
my truck is already lowered 2/3, but should I address the lean before moving forward or ignore it? I already know why the lean is happening. Y’all think a 1.25 inch coil spacer would solve it at least in the front?
franklin2
1,769
Virginia
Bronco II
Apparently you think the coil springs up front are the problem?
MSGia
124
Central Florida
4, 5
Well, people are saying all rangers kinda lean because battery, driver, and gas tank are on one side
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
I have a 5/3 drop using Belltech 3" springs and DJM lower arm, and DJM flip kit. Mine had a noticeable lean when I first did it, but now after a year, the height difference is barely noticeable. I think there's a 3/4" difference between left and right. I was also thinking about relocating the battery to the right, front corner of the bed.
MSGia
124
Central Florida
4, 5
I thought I would revisit this thread now that I did the 4/5 DJM kit for anyone looking for info. The difference from left to right went down to 3/4" which is so much better and less noticeable. I am still debating trying to reduce it by cutting 1/2" off the passenger coil spring and using blocks in the rear, but I don't notice it that much so it doesn't bother me much anymore.
