ranger ll
xgenralxleex01x
orlando, florida
doin a dana 44/ 9 in swap with 10 in lift and 3 in body on 38.5 tsls, in my 90 ranger will post pix as soon as i start.
3,614
Something like 5.43 gears oughtta make that work right.
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
i thought the highest you go could go was 5.13 unless its ina rockwell or somthing
________
Web Shows
3,614
I think it is, I'm honestly not even sure if anyone makes a 5.45 gear. I just picked a number that would be a ridiculously low ratio.
BONES
4
Canada Eh!!
gt40 5L
It's actually the 8.8 that will limit your low gear ratios, the dana axles go quite low for aftermarket gears. I looking at buying the 5.38/5.42 combo for my d44/9" combo.
kris97ranger
36
lisle ontario
how will that work i thought gear ratios had to be the same? or is it too small of a difference to matter
________
Bubbler Pipe
3,614
He might get away with that gearing, especially if it's a trail toy, which I'm sure it is with that lift.
No members online now.
