Ranger not starting
Roll
Ford ranger
I have a 1983 ford ranger, where it won’t start I replaced to battery about a month ago an optima. It is showing 12 bolts as well, but when I turn the key to turn it over nothing happens, not even dash lights any help?
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
If it’s an automatic, is it in park or neutral? If it’s a manual are you pressing the clutch pedal? Have you checked the connection to the battery? Clean and secure? Are the connections to the solenoid secure?
Roll
Ford ranger
It’s an automatic and yes it is in park the connections are good, haven’t checked the solenoid but the thing is the dash lights don’t come on. And it doesn’t turn over
8,374
There should be a positive battery cable to the starter relay(often called solenoid), its mounted on the inner fender, has 2 larger posts and 1 or 2 smaller posts
FIRST remove battery negative cable!!!!!
Then remove battery positive cable from the Relay/Solenoids larger post, there WILL BE several other wires with it, those wires power the dash and all the other electrics in the vehicle
So this is a very important post/connection
Clean it and all the wire ends, and put them all back on, and secure the nut
Now clean the battery negative cable end, its post should be clean if its a new battery, its a lead connector so soft metal, scrape it clean on the inside if needs be
Connect it to battery and tighten it
Remove battery positive from battery and clean it, put it back on and tighten it
Battery cables MUST BE tightened to work
Roll
Ford ranger
So I cleaned the battery cable and the solenoid posts like you said and I provided some pictures for you guys to see but it still has the same issue
Roll
Ford ranger
If I move the key back a little bit the radio turns on but only flickers it is aftermarket
8,374
Looks like someone has added some inline fuses or connectors seen in 1st picture under relay
Check them
None of that is factory wiring, wires on positive battery cables terminal should be on the relays larger post with other end of battery positive cable
Batteries vent gases when charging/driving so will corrode those wire ends over time
One battery negative cable, check its other end, clean and tight
"If I move the key back a little bit the radio turns on"
Could be ignition switch under the steering column has failed, these older ones were known to split apart, could be made to work using zip ties to hold them together
The key itself turns a gear that slides a rod inside the column, that rod slides the ignition switch into its 4 positions, ACC, OFF, RUN, START
Roll
Ford ranger
Check them
The battery post cables should be on the solenoid? And I’ll check those other things as well
Roll
Ford ranger
On the big post of the solenoid? Where the other end of the battery cable is connected on the solenoid?
8,374
Yes, same 12volt connection to battery but away from vented gases from battery
cyclejohn
11
Reidsville, NC
Ford Bronco II
2.8 V6
Almost the same exact symptoms that I experienced. Get it done.
Until you open up the clamshell around the steering column and check it, nothing else matters (just like the song).
John
cyclejohn
11
Reidsville, NC
Ford Bronco II
2.8 V6
Oooh, one more thing, be careful and watch, there is a detent ball that likes to go crazy when released.
John
8,374
Yes
Not your issue, but thats where they should be
