Ranger poly spacers how-to online?!?!?
IdRatherPushMyFord
Phoenix, AZ
2.3
Hey guys: I was wondering if anyone knows of a how-to on installation of 2" front Poly spacers and rear Ad-A-Leaf stuff?? I just bought a set here from RobinHood and don't really know what's gonna be involved in installing them. He said that there were instructions to be found here online somwhere, and I'm sure there are, I just don't know where to look. Thanks -Josh. (This is the set I've got):
Bryan22
4
So-Cal babay
94 extd
94 2.3
techlibrary on this site has some info. on installing different types of leveling spacers.
fordboi415
rancho cucamonga california (socal)
3.0V6
Add a leaf is easy, just take the leaf pack off your truck, break it and insert the add a leaf where it fits, bolt em back together and reinstall it on your truck, as for the front I would suggest renting a coil spring compressor from autozone
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
A coil spring compressor is not needed at all. You just have to undo the shock and sway bar end links, remove the lower coil retainer nut (1 1/8" wrench or socket). The vehicle needs to be supported by the frame not the suspension. Step down on the hub and it will droop far enough to get the spacer in under the coil seat. Reinstall everything in reverse order and take it in to have it aligned. Voila.
rickcdewitt
5
nor-cal
4-0 swap
step one,throw away the poly and get solid spacers.they won't squash down and break up like the poly
