Slim
- Nov 19, 2008
- 5
- Ontario, Canada
- Ford
- Engine Size
- 3.0 and 4.0 SOHC
I figured i'd post about this and see if anyone has some wisdom to share. I hope you don't mind the length, but I like to be thorough and need help.
I've had my truck for a year. I enjoy it. It doesn't cost a ton of money to run, so that's a big help. I bought it because it's a Ford, rwd, can haul stuff, handles decent, looks good and is very versatile (dare I say almost too much so). I feel that I need more from it, though.
Since I bought it I had discovered the famous saggy front springs problem, so I bought a SkyJacker 2" lift kit (new coils up front and AALs out back), 235/75-15 BFG AT's and a 3" BL. The idea was to stop the suspension from bottoming in the front (absolutely UNACCEPTABLE!)
Didn't care much for the firmer ride in the back, so I removed the AALs and replaced with a 1" custom spacer. Better. (axle wind up was crappy though with the bigger tires)
I also didn't like how the tires slowed the truck down as much as they did (didn't re-gear - my bad!), so those were replaced with stock 235/60-15 Firestone Indy 500s. Better. (and no more axle wind up)
Then I figured I wasn't gonna lift it afterall, so I sold the BL kit I had.
I also needed new shocks, so Rancho 5000s all around. Those are still in the truck right now.
Since then i've acquired an 8.8 out of a Ranger that I want to install so I can have a TracLoc differential (hopefully install by end of this year). Since I want the TracLoc so bad I want to get my butt in gear and ..... decide SOMETHING! I really don't want to have to re-gear it twice, but I just can't help but think that I really don't know wtf I want to do. I would be using different gears depending on if I lift or lower and I only want to buy them once (having a mortgage and buying everything twice because I can't make up my mind is pissing me off lol).
If I lift it i'd like to get 31s, so i'm pretty sure i'd need a 3" BL to get those to fit well. I know that not re-gearing with the bigger tires was a mistake before, so I wanna be sure I do this properly this time (might also help with axle wind up ..... ?). If I lower it then I get DJM beams and probably shocks (not sure what i'd do with the rear yet, either axle or shackle flip). Either way the new rear end get's geared.
Truck is used 95% for street, commuting back and forth to work, and also as the occasional furniture/garbage hauler. I like the idea of lifting largely for sake of safety (in a collision), but not for economy (yeah, I said economy about a pick up truck with big tires). I like the idea of lowering because of better handling and potentially safer load hauling, but not for bottoming suspension (I know the beams should solve this tough). Truck is currently slightly lifted so I figure it's around a ride height that is a compromise right now. All my life i've been a V8 rwd guy, so having a lifted truck is appealing ..... but i'm not sure if it's just a phase or something. (key point!)
I don't have a preference (although if I could afford 2 i'd have one lifted and one lowered and be happy). I want something that I can drive reliably, comfortably and safely.
If I had to complain about my truck in any way right now i'd say I don't care much for the ride. Then again it's a pick up truck, so i'm not sure how much better it could get.
Just for ****s and giggles i'll post a pic. PLEASE tell me what you think. I've spent hours searching and looking at pics and just can't make up my mind. I'm hoping that there may be a few key points brought to my attention that I haven't thought of yet that'll help.
THANKS!
The way it sits now ..... 2" Skyjacker lift springs up front, 1" custom spacer in rear, 235/60R15 Indy 500s.
With BFGs a few months ago ..... same as above, but with the AALs in the back instead of the 1" spacer.
When I bought it ..... with saggy front springs
I have a pic I Gimp'ed with a 3/3 drop, but I can't post it on PhotoBucket. Looks neat though!
THANKS!
