Rear Door Window Replacement?
rickbrew
Hi Rangerstation Team,
can anyone help with replacing the right rear door glass in a 2002 Ranger Extended Cab? Apparently mine was broken at the car wash and I didn’t even realize it until the next day. Can’t find any info on replacing it. Any help greatly appreciated!
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
Saskatchewan...hard to spell...easy to draw
First remove top seatbelt mount with 15 mm socket. Then prepare to break every clip holding the panel on. Start at the top and work your way down. If you want to remove bottom seatbelt anchor it is a T 50. This way you can completly remove the panel. Viola...there it is...4 fastener thingys that hold the window in place. There will be some sticky schmoo that holds the glass in also. Razor knife to the rescue. https://www.therangerstation.com/forums/index.php?threads/removing-rear-quarter-glass-from-3rd-gen-ranger.191127/
rickbrew
Thanks Corbin. I received my glass yesterday and am going to attempt it. What confuses me is that there is still a piece of glass intact on the inner side of the window. Is this glass double glazed?
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
I'm a bit confused...do you have a picture?
