Rear locker, tire sizes
BroncLander
412
BC Canada
XLS Bronco II
Tire size is definitely dependant upon the terrain. For rock crawling you want as big as possible. But for what most of us do, which is veer off a logging road to get into the locally hidden fishing hole, a bit bigger, slightly aggressive tread is fine. My last vehicle has a 2 1/2" lift and 32 inch Duratracs (I highly recommend this tire) and this one I bought has a 4 inch lift and 31s. I think they'll do just fine and I'll probably never fully use the articulation this truck has.
I had a limited slip in the last rig and one in this as well.
My favorite mod of all time is a winch. It will get you over, out, through damn near anything. It's next on my list for this Bronco II. I had an Evo 8000lb Warn on the last one and I think I'll go with it again but with synthetic rope this time. (In hindsight I should have removed my winch before selling the Jeep. Oh well)
JER-BEAR-ID
Klamath Falls, Oregon
Ford Fuckin Ran
Also, another thing to consider with tire sizes and clearances is wheel width... wheel width can change the way your tires clear and/or look quite a bit really! I've got a set of 33/10.50/15 and with them mounted on a 10" wheel, they look like 33/12.50/15 but on a, say, 7" or 8" wheel they are super tall and narrow... almost doesn't look like the same set of tires...
00t444e
217
Southern OH
Ranger ext cab
A 10.5" wide tire on a 10" wide wheel? That's a bead popper for sure, I won't even use a 10" wide wheel on a 12.5" wide tire, I stick with an 8".
JER-BEAR-ID
Ford Fuckin Ran
Well, I haven't had any issues in the last almost 20 years... Obviously you're not gonna air down to 15 lbs and go play in the woods but almost any aggressive swamper has enough meat coming down into the sidewall, it doesn't look abnormal at all... But to each their own! That's all besides the point anyhow... I was simply saying, it's just another thing to consider...
BroncLander
412
BC Canada
XLS Bronco II
I have 15" 31x10.5 mudders on 7" Daytona rims. And I tried getting a matching spare. Tire shops can't find the same rims anymore, they all went to 8"
BroncLander
412
BC Canada
XLS Bronco II
That's messed up! Have you tried online?
Not really. I figure I'll post on kijiji and see if anyone has any laying around. It seems they're about 20 yrs old. And if I get a 5th wheel and tire,I want the exact same because I'll rotate them. The tire shop was like, just get an 8" rim and it'll be close enough. And as he said that my OCD reminded me that I'll never buy my tires there. Ever
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I always use the manufacturer recommended rim size. Keeping the contact patch optimal. A too small rim will round the tread and wear the centers unless you air down to get the contact patch back to normal. Too big of a rim will do the opposite. Cup the tread and wear the edges.
My two cents. 😜
00t444e
217
Southern OH
Ranger ext cab
ericbphoto
Overlander in development
16,707
Wellford, SC
6"
Don’t be scared. I run BFG Mud Terrains 35x12.50-15 on 10” wide wheels and air down to 12psi for rock crawling, sand, mud, etc. Never popped a bead.
