Rear sway bar?
fiddlermd
07417
Mazda B4000
I recently got a 2003 b4000 and noticed there's no rear sway bar. As far as I understand, there are a number that would fit but I also don't know whether the necessary mounting points / hardware is there or not.
can someone point me to the correct parts needed to get this done?
thanks!
pjtoledo
2,992
Toledo Ohio
Fords
3.0 2.3
there are factory holes in the frame for the end links. the bar itself attaches to the axle with big clamps. so all older Rangers are capable of accepting a rear sway bar.
I'll try for some pics later.
by the way, a rear sway bar has an undesirable side effect. it lifts the inside rear wheel while turning.
that's most noticeable when pulling away from a stop while turning, especially with an open differential.
this is from LMC, it does not show the axle clamps very well.
66651
cbxer55
767
Midwest City, Oklahoma
I have a Hellwig on the rear of my 98. It does not mount like the stock bar, and actually may be considerably easier. Yes, it uses pre-existing holes to mount. Also the Hellwig is thicker than the stock bar. Doesn't affect straight driving, since the bar just rolls in the axle mounts. But get going around corners, a thicker bar helps prevent body roll.
The side mounts pictured with the wheels, actually only use the upper bolt, which is pre-existing in the frame. I drilled and added the lower bolt. Probably not necessary and overkill, but that's the way I roll. The end links and the axle mounts are all Energy Suspension replacement parts. The originals were on the truck since 2002 and pretty badly deteriorated.
