exhaust manifold bolt replacement
typical stainless steel bolts are slightly weaker than grade 5 SAE bolts, but as stainless doesn't rust the bolts won't grow weaker.
But be aware that stainless steel bolts and nuts tend to gall together, particularly when heated and subjected to vibration, so smearing them liberally with never-seeze is more imporntant than on rust prone carbon steel.
THE thing to warn you about is that both the bolts and the threaded holes in the exhaust manifolds are a "Truncated root thread" which make inserting a conventional bolt into the hole an "interference fit" (threading together two interference fit parts make them really sticky)
Even so when I still did that work I averaged getting three out of four bolts out of the holes.
On the bolts that hold the manifolds to the heads there is another problem.
The threads are common metric 8mmX1.25 thread, these aren't a problem to replace.
What is a problem is that commonly available metric bolts are only available
in the necissary lengths in 10mm incrementsare either too long or too short
My usual way to deal with this has been to helicoil the twelve 8mm holes
to 5/16-18 UNC (english/american) threads to allow the use of common bolts
that I can buy ANYWHERE (Tractor Supply sells grade-8 bolts by the pound)
The only rub with this is that now when I want to tighten the bolts on my exhaust manifold
I need to keep track of my 1/2" socket.
I've got the top end of my 1999-2000 Ranger/Explorer engine on my work bench. I broke 6 of 12 exhaust manifold studs/bolts and of the other six five of the studs came out with the nut still attached. Only one nut came off leaving the stud intact.
I picked up a package of two 8mm-1.25 x 50mm 8.8 bolts at Tractor Supply.
It would appear that if I cut them of to the same (or slightly longer) length than the original studs, I could install them as studs by double nutting them to get them tight into the manifolds. I'm also considering getting bolts in correct length rather than the stud/nut combination. Perhaps a combination of two studs, four bolts. The idea of that would be to use the two studs to "hang" the manifold on the head and make it easier to install the four bolts.
It shouldn't be that hard to determine how long the bolts should be to reach into the head far enough to hold tight but NOT bottom out. I'm guessing that 40mm would be good and since I've got the heads and manifolds out on the bench I can test them before final install.
I wonder if I could find 8mm-1.25 pitch bolts in 5mm increments?
coopab
alternatively, if I remove the old studs by drilling and tapping, could I tap 5/16-18 threads in order to use more widely available SAE size studs? without requiring helicoils?
